All updates applied with the exception of Home Assistant Core
Upgrading from 2025.10.4 to 2025.11.1 puts Home Assistant in recovery mode.
Same occurs when trying to upgrade from 2025.10.4 to 2025.11.2.
Log attached.
e[33m2025-10-28 09:01:56.426 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[31m2025-10-28 23:02:16.324 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned 503e[0m
e[31m2025-10-28 23:02:16.324 ERROR (MainThread) [homeassistant.components.met.coordinator] Error fetching met data: Update failed: e[0m
e[33m2025-10-29 11:54:02.823 WARNING (MainThread) [google_nest_sdm.event_media] Failure when pre-fetching event 'AVPHwEul9JCAYRDhDrLxhGxCEH_Wbbzufpzusdd81Mb6aifc8UK1Tm2EmY0MlR_r_yWPgBDgBmZ6vujEzWE4fUOnGuWErQ': Bad Request response from API (400): FAILED_PRECONDITION (400): The camera is not available for downloading event image.e[0m
e[33m2025-10-30 19:09:57.504 WARNING (MainThread) [google_nest_sdm.event_media] Failure when pre-fetching event 'AVPHwEux8yF99fahVCbrSo6w8CJSGhyc0FWBOESY6b0oZRByzvAEJs8Ka-HBYcUWkxzSr2VZbL7Psy2hWLHKybLOmXUXQA': Internal Server Error response from API (500)e[0m
e[33m2025-10-31 07:32:32.835 WARNING (MainThread) [google_nest_sdm.event_media] Failure when pre-fetching event 'AVPHwEusf58dJ2PV7IeBamRMo7ZGurEG2o2-veQ7XQlRmS7y62OkVfRLcKOhydCmMYuDAYqnk3EZIwA7BWvr78pE7ffKbA': Bad Request response from API (400): FAILED_PRECONDITION (400): The camera is not available for downloading event image.e[0m
e[33m2025-10-31 19:45:13.480 WARNING (MainThread) [google_nest_sdm.event_media] Failure when pre-fetching event 'AVPHwEvJdBXu-tBX02qtJz8We7K380NQG7VCQHnFPtIYqF6At2A33WrJHykGfzJ6HTXDUvK2aBcRi9KQlnlZIZYHyUaNWQ': Internal Server Error response from API (500)e[0m
s6-rc: info: service legacy-services: stopping
e[33m2025-11-02 01:04:21.754 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-471797' coro=<ConfigEntries.async_reload() running at /usr/src/homeassistant/homeassistant/config_entries.py:2298> wait_for=<Future pending cb=[BaseSelectorEventLoop._sock_write_done()(), Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdowne[0m
e[31m2025-11-02 01:04:21.755 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Matter for matter
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 761, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/matter/__init__.py", line 70, in async_setup_entry
await _async_ensure_addon_running(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/matter/__init__.py", line 285, in _async_ensure_addon_running
addon_info = await addon_manager.async_get_addon_info()
File "/usr/src/homeassistant/homeassistant/components/hassio/addon_manager.py", line 53, in wrapper
return_value = await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/addon_manager.py", line 152, in async_get_addon_info
addon_store_info = await self._supervisor_client.store.addon_info(
self.addon_slug
File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/store.py", line 34, in addon_info
result = await self._client.get(f"store/addons/{addon}")
File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 170, in get
return await self._request(
...<5 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 127, in _request
response = await self.session.request(
...<7 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 770, in _request
resp = await handler(req)
File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 725, in _connect_and_send_request
conn = await self._connector.connect(
req, traces=traces, timeout=real_timeout
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 642, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1209, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1550, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
...<7 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1268, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 73, in start_connection
sock = await _connect_sock(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py", line 208, in _connect_sock
await loop.sock_connect(sock, address)
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
return await fut
asyncio.exceptions.CancelledError: Home Assistant final writes shutdown stagee[0m
[08:04:23] INFO: e[32mHome Assistant Core finish process exit code 0e[0m
[08:04:23] INFO: e[32mHome Assistant Core service shutdowne[0m
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
e[33m2025-11-02 01:04:53.010 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-03 09:46:53.751 WARNING (MainThread) [google_nest_sdm.event_media] Failure when pre-fetching event 'AVPHwEuDkUTxJA8KkNScn_BGYNZTBJGe1yZVvcnrPePHBGrM1gkqffrirHR0kmcxlU83finFIz8uPE_zBYcaVraPJvpesQ': Not Found response from API (404)e[0m
e[31m2025-11-04 22:26:57.423 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorDNSError'e[0m
e[31m2025-11-04 22:26:57.423 ERROR (MainThread) [homeassistant.components.met.coordinator] Error fetching met data: Update failed: e[0m
e[33m2025-11-09 01:03:38.605 WARNING (MainThread) [homeassistant.core] Task <Task pending name='Task-712589' coro=<ConfigEntries.async_reload() running at /usr/src/homeassistant/homeassistant/config_entries.py:2298> wait_for=<Future pending cb=[BaseSelectorEventLoop._sock_write_done()(), Task.task_wakeup()]> cb=[set.remove()]> was still running after final writes shutdown stage; Integrations should cancel non-critical tasks when receiving the stop event to prevent delaying shutdowne[0m
e[31m2025-11-09 01:03:38.607 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Matter for matter
self.addon_slug
...<5 lines>...
...<7 lines>...
...<7 lines>...
...<6 lines>...
...<6 lines>...
return await fut
[09:03:39] INFO: e[32mHome Assistant Core finish process exit code 0e[0m
[09:03:39] INFO: e[32mHome Assistant Core service shutdowne[0m
e[33m2025-11-13 08:30:20.057 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-13 08:30:20.493 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanlye[0m
Exception ignored in: <function _SelectorTransport.__del__ at 0x7f7a727832e0>
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 872, in __del__
self._server._detach(self)
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 303, in _detach
self._wakeup()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 308, in _wakeup
for waiter in waiters:
TypeError: 'NoneType' object is not iterable
[16:35:36] INFO: e[32mHome Assistant Core finish process exit code 0e[0m
[16:35:36] INFO: e[32mHome Assistant Core service shutdowne[0m
e[33m2025-11-13 08:36:23.234 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
[16:38:12] INFO: e[32mHome Assistant Core finish process exit code 0e[0m
[16:38:12] INFO: e[32mHome Assistant Core service shutdowne[0m
e[33m2025-11-13 08:56:21.349 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2025-11-13 08:56:21.775 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanlye[0m
