Can't upgrade to 2023.8.1
trying to upgrade to 2023.8.1 (pip3 install homeassistant==2023.8.1… see below, version isn’t available but latest version is 2023.8.1 - any ideas what may be wrong ?
3, 2023.7.0b0, 2023.7.0b1, 2023.7.0b2, 2023.7.0b3, 2023.7.0b4, 2023.7.0b5, 2023.7.0b6, 2023.7.0, 2023.7.1, 2023.7.2, 2023.7.3)
ERROR: No matching distribution found for homeassistant==2023.8.1
Just use pip install homeassistant
Did you remember to use Python 3.11(.4) for your venv?
pip3 install homeassistant → installs 2023.7.2
i’m using python 3.10
From Breaking Changes:
HA has a very clear Python deprecation policy, as you’re using a venv you need to ensure you keep rebuilding your venv with the current supported version (which may include a minor version requirement).
Alternatively just use Docker.
got it … must have missed the announcement
upgraded to 3.11
i’ve got two errors aiodiscover and webrtcvad both fail to load
any ideas how to correct ?
What are the actual errors?
