I’m using the Z-Wave JS to MQTT add-on together with the Z-Wave JS integration to control my Z-Wave devices. I use the second input on many of my modules to trigger scenes or controlling other devices. This works great when using Fibaro modules, the second virtual input is shown as a second light.x device.
However, with the Qubino Flush Dimmer device this doesn’t work. I get a second light.x device but it’s not changing status when I switch the attached button. If I remembered correctly Qubino devices showed the second input as a motion sensor when I used it with another controller, but I don’t get any child devices like this when added to Home Assistant.
Have anyone got the second and third virtual inputs on a Qubino dimmer to work?
Go to Configuration, Devices & Services.
Click on Devices at the top of the screen, then click on the Qubino device that you want to use I2/I3 for.
You’ll find I2 and I3 in the section SENSORS. They are disabled by default, so you need to unhide and figure out which ones they are… On my I see them as
Flush 1 relay: Any (2)
Flush 1 relay: Any (3)
and they can be On or Off.
You need to click on these and ENABLE them.
You might aslo see something with Home Security, which seem to be I2 and I3 as well. If you go to the Configure device, you can scroll down and change what type of event it should be.
