I’m trying to replace a failed RGB lightbulb running ESPHome with a new bulb.
I successfully installed a the old ESPHome configuration on a new bulb.
From the ESPHome dashboard, the new bulb appears correct, with the proper entity ID. I can visit the device or display the logs.
But from the device info for the entity, if I click on ‘visit’, it takes me the the IP address of the old, dead bulb.
How can I fix this, other than renaming the device. I’m tired of the system renaming endities all the time and don’t want to do it myself.
Is there a DHCP table in Home Assistant that needs to be updated? The router’s DHCP is correct.
I can’t seem to delete the old entity in HA, only disable it.
