Can't use scenes with knx - getting "Unable to find component scene.knx"
Hi all.
I’m using the Raspberry pi 2 image from hassio. Everything is working great except for KNX scene (all other KNX components are functioning). I’ve updated to latest version of hassio but I still get this:
scene:
platform: knx
address: 2/0/13
scene_number: 16
I get the following error when validating configuration:
ERROR:homeassistant.loader:Unable to find component scene.knx
ERROR:homeassistant.config:Invalid config for [scene]: platform knx does not exist for scene for dictionary value @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 89). Please check the docs at https://home-assistant.io/components/scene/1
Failed config
General Errors:
  • Platform not found: scene.knx
Any ideas with what’s wrong with my syntax? I understand there’s another scene component? How do I install the KNX scene component or reference it properly?
If anybody runs in to this it turns out that KNX scene support is not in the official version just yet. I downloaded it from https://github.com/Julius2342/home-assistant and placed the knx.py file in the scene folder under my hassbian installation and it started working like a charm. Thanks Julius for developing this.
This has been fixed in a later release…
