Description
This blueprint automatically logs the start and end of your car trips when your phone connects/disconnects from your car’s Bluetooth. It saves trip data like time, location, and Waze-estimated travel duration to a Google Sheet.
It requires:
- Companion App with Bluetooth and Geolocation sensors enabled
- Waze Travel Time integration
- Google Sheets integration
Requirements
Bluetooth Binary Sensor
Create a Template Binary Sensor that detects when your phone is connected to your car. -
Helpers
input_texthelpers for start time, start location, end location, etc.
- Integrations
- Waze Travel Time
- Google Sheets
- Device Tracker & Geolocation
Use the Companion App’sdevice_trackerandsensor.geocoded_location.
Setup Instructions
- Create the required Helpers (
input_text) - Enable Companion App sensors
- Setup Google Sheets + find your
config_entry_id - Configure Waze Travel Time (region, units, vehicle type, etc.)
- Replace placeholder values in the Blueprint inputs
Example Use Case
Log every work commute automatically into a spreadsheet with time, address, and travel data.
We needed to log when the car was used for work to claim this for tax, this is why I made this automation.
Note:
Any change to the value of the latitude and longitude action, will likely break your automation.
Blueprint YAML
blueprint:
name: Car Travel Log
description: >
Tracks the start and end of car trips based on Bluetooth connection events.
Logs time, location, and Waze-estimated travel data to Google Sheets.
Requires: Waze Travel Time, Google Sheets, Companion App location and Geolocation sensors.
domain: automation
input:
bluetooth_sensors:
name: Bluetooth Trigger Sensors
description: >
A **Template Binary Sensor** that becomes `on` when your phone is connected to any of your car's Bluetooth devices.
This sensor is created using the Companion App’s Bluetooth sensor, which shows the list of connected
Bluetooth devices under the `connected_paired_devices` attribute.
👉 **Steps to create it:**
1. Go to: **Settings > Devices & Services > Helpers > Create Helper**
2. Choose: **Template Binary Sensor**
3. Name it something like: `Garage Car Bluetooth`
4. Set the template like this:
{{ 'A8:54:B2:F4:C1:98 (Skoda_VR)' in state_attr('sensor.name_phone_bluetooth_connection','connected_paired_devices') or
'A8:41:F4:0A:EE:3A (AndroidAuto-ee3b)' in state_attr('sensor.name_phone_bluetooth_connection','connected_paired_devices') or
'00:92:A5:3E:30:47 (Kia)' in state_attr('sensor.name_phone_bluetooth_connection','connected_paired_devices') }}
📌 Replace each MAC/name string above with your actual car’s Bluetooth identifier. You can find these by:
- Enabling the Bluetooth Connections sensor in the **Companion App** (`Settings > Companion App > Sensors > Bluetooth Connections`)
- Viewing the attribute `connected_paired_devices` under your phone’s Bluetooth sensor (e.g., `sensor.name_phone_bluetooth_connection`) in Developer Tools > States.
You can add as many cars as needed by chaining more `or` conditions following the same format.
selector:
entity:
domain: binary_sensor
multiple: true
device_tracker:
description: Device tracker for location and speed
selector:
entity:
domain: device_tracker
geocoded_sensor:
name: Geocoded Location Sensor
description: Sensor with the current location in text
selector:
entity:
domain: sensor
text_trip_start_time:
name: Input Text - Trip Start Time
description: Create a Text Helper for Trip Start Time
selector:
entity:
domain: input_text
text_trip_start_location:
name: Input Text - Trip Start Lat,Lon
description: Create a Text Helper for Trip Start Location
selector:
entity:
domain: input_text
text_trip_start_address:
name: Input Text - Trip Start Address
description: Create a Text Helper for Trip Start Address
selector:
entity:
domain: input_text
text_trip_end_location:
name: Input Text - Trip End Lat,Lon
description: Create a Text Helper for Trip End Location
selector:
entity:
domain: input_text
google_sheets_config_entry:
name: Google Sheets Config Entry ID
description: >
Paste your Google Sheets config_entry ID.
Find it under `.storage/core.config_entries` or Developer Tools > Services > `google_sheets.append_sheet`.
selector:
text:
google_sheets_worksheet:
name: Google Sheets Worksheet Name
description: >
The name of the sheet tab at the bottom of the Google Sheet (default file: "Home Assistant").
default: Travel Log
selector:
text:
waze_region:
description: Controls which Waze server is used
default: au
selector:
select:
options:
- us
- na
- eu
- il
- au
waze_units:
description: Unit system to use
default: metric
selector:
select:
options:
- metric
- imperial
waze_vehicle_type:
name: Waze Vehicle Type
description: Vehicle type for routing
default: car
selector:
select:
options:
- car
- motorcycle
- taxi
- truck
waze_real_time:
name: Real-Time Travel Time
description: Use real-time or statistical data
default: true
selector:
boolean: {}
waze_avoid_toll_roads:
name: Avoid Toll Roads
description: Whether to avoid toll roads
default: false
selector:
boolean: {}
waze_avoid_ferries:
description: Whether to avoid ferries
default: false
selector:
boolean: {}
waze_avoid_vignette_roads:
name: Avoid Vignette Roads
description: Whether to avoid subscription roads
default: false
selector:
boolean: {}
allowed_days:
description: Only run the automation on these days
default:
- monday
- tuesday
- wednesday
- thursday
- friday
- saturday
- sunday
selector:
select:
multiple: true
mode: list
options:
- monday
- tuesday
- wednesday
- thursday
- friday
- saturday
- sunday
- platform: state
entity_id: !input bluetooth_sensors
to: "on"
- platform: state
to: "off"
variables:
selected_days: !input allowed_days
condition:
- condition: template
value_template: >
{% set days = selected_days if selected_days is iterable and selected_days is not string else [selected_days] %}
{{ now().strftime('%A') | lower in days }}
- variables:
tracker: !input device_tracker
geocoded: !input geocoded_sensor
start_time: !input text_trip_start_time
start_location: !input text_trip_start_location
start_address: !input text_trip_start_address
end_location: !input text_trip_end_location
- choose:
- conditions:
- condition: trigger
sequence:
- service: input_text.set_value
entity_id: !input text_trip_start_time
value: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
entity_id: !input text_trip_start_location
value: >
{{ state_attr(tracker, 'latitude') }}, {{ state_attr(tracker, 'longitude') }}
entity_id: !input text_trip_start_address
value: "{{ states(geocoded) }}"
- conditions:
value_template: >
{{ state_attr(tracker, 'speed') | float(0) == 0 }}
sequence:
entity_id: !input text_trip_end_location
value: >
- delay:
seconds: 1
- service: waze_travel_time.get_travel_times
origin: "{{ states(start_location) }}"
destination: "{{ states(end_location) }}"
region: !input waze_region
units: !input waze_units
vehicle_type: !input waze_vehicle_type
realtime: !input waze_real_time
avoid_toll_roads: !input waze_avoid_toll_roads
avoid_ferries: !input waze_avoid_ferries
avoid_subscription_roads: !input waze_avoid_vignette_roads
response_variable: travel
- delay:
minutes: 1
- service: google_sheets.append_sheet
config_entry: !input google_sheets_config_entry
worksheet: !input google_sheets_worksheet
Start Time: "{{ states(start_time) }}"
Start Address: "{{ states(start_address) }}"
EndTime: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"
Duration: "{{ travel.routes[0].duration | round(1) }} mins"
Distance: "{{ travel.routes[0].distance | round(2) }} km"
End Address: "{{ states(geocoded) }}"
mode: single
