Card for showing Liquids (fluid-level-background-card)
The very first post is about a similar case.
So I feel like I am close,
But its filling the entire card still. My image is now transparent inside the gas tank.
Its not just filling inside the tank, the whole card background is filling?
Any ideas?
type: custom:fluid-level-background-card
card:
  show_state: true
  show_name: false
  camera_view: auto
  type: picture-entity
  image: /local/images/bottle.png
  entity: sensor.camper_gas_weight_left_bottle_2
fill_entity: sensor.camper_gas_weight_left_bottle_2
background_color:
  - 0
  - 143
  - 81
severity:
  - value: 42
    color:
      - 255
      - 0
      - 0
full_value: "100"
You need to use picture-elements card like was proposed in the 1st post.
How do you get rid of the overlay on the outside of the card (specifically Mushroom)?
card:
  type: picture-elements
  elements:
    - type: state-badge
      entity: sensor.smartoiltank
      style:
        color: transparent
        top: 54%
        left: 37%
      tap_action:
        action: none
      hold_action:
        action: none
  image: >-
    /media/local/OilTank_transparent3.png?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiI4OGI0ZDI4MzViNWQ0MjNiYmU2ZWRlMWMzNDc3ZjVjYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvT2lsVGFua190cmFuc3BhcmVudDMucG5nIiwicGFyYW1zIjpbXSwiaWF0IjoxNzQ0NTcxODQxLCJleHAiOjE3NDQ2NTgyNDF9.eyoi3r1pQkyZNsQFsovxBi9GGW0C6iXx7WQFl4UQ8Pc
fill_entity: sensor.smartoiltank
theme: mushroom
severity:
  - value: 187
    color: red
  - value: 180
    color: green
  - null
full_value: "330"
grid_options:
  columns: 6
  rows: auto
These cards are great.Here is a dashboard I just finished;
That I don’t know, still appears on mine.
This looks brilliant.
What are you using for the graphs?
apexcharts card
type: custom:mod-card
style: |
  ha-card {
    border: 2px solid rgba(92, 100, 127, 0.2); /* Hvid ramme */
    border-radius: 20px; /* Afrundede hjørner */
    padding: 2px; /* Indvendig margin */
    background-color: rgba(92, 100, 127, 0.1)
card:
  card:
    show_state: true
    show_name: true
    camera_view: auto
    image: local/vandtankpalle12.png
    entity: sensor.resterende_vand_i_tanken
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 10%;
          left: -2%;
          width: 105%;
          height: 80%;
  fill_entity: sensor.resterende_vand_i_tanken
  severity:
    - color:
        - 82
        - 171
        - 255
      value: 0
    - color:
        - 112
        - 200
        - 255
      value: 20
    - color:
        - 56
        - 179
        - 255
      value: 50
    - color:
        - 20
        - 145
        - 255
      value: 80
  full_value: 1100
  grid_options:
    columns: 9
    rows: 1
Please share a png image, many people use these cubes in gardens.
Does anyone have any suggestions for a reliable water level sensor that I could use with this card? I’d like to install one in the reservoir of my hydroponics system.
Water container and pellet stove
site : Redirecting...
outdoor:
https://esphome.io/components/sensor/jsn_sr04thttps://esphome.io/components/sensor/jsn_sr04t
indoors
https://esphome.io/components/sensor/ultrasonic
VANDING BEHOLDER:
esphome:
esp8266:
  board: d1_mini
# Enable login
logger:
# Enable Home Assistant API
api:
ota:
  password: "1234564k4j4k4j4k4k4lm4jl4lj4lj4lj4"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Vanding-Beholder-Indhold"
    password: "h4hh4h4k4"
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 120s          #to display WiFi signal strength
  - platform: ultrasonic
    trigger_pin: D5
    echo_pin: D6
    unit_of_measurement: "%"
    icon: "mdi:water-percent"
    accuracy_decimals: 0
    update_interval: 20000ms
    name: "Sweet Water storage"              #You may change the tank name
    filters:
      - lambda: return (1-((x-.13)/0.90))*100;
      - filter_out: nan
    trigger_pin: D5
    echo_pin: D6
    update_interval: 20000ms     #5 minutes. You can change this value
    name: "Resterende vand i tanken"
    unit_of_measurement: "l"
    filters:
      - lambda: return (1-((x-.13)/0.90))*1000;
      - filter_out: nan
It’s all laid up
Thanks so much for providing the simplified code and image.
I was also struggling with the original image posted which I want to use but it’s not transparent.
Has any got a transparent version of the cylinder image which can be used so the fluid level shows?
is there a secret how to get the picture transparent? I can see the image and you can also guess from the edge that the water level is displayed in the background. However, it seems that the image covers everything. What am I doing wrong?
Thanks for the support!
Regards,
Tobias
One option is to use a free background remover
https://www.adobe.com/express/feature/image/remove-background
Thanks, I just removed the white boxes. Now it works. I’ve attached to picture with tranparency.
I didn’t know that one yet, years ago I found Lunapic at LunaPic.com Photo Editor Load tool, and still return if I need it…
what they do with all of that info you throw at them…
Saved your link and appreciate the info!
Does anyone have a link to a horizontal oil tank png file and/or the yaml code to use with fluid level background card?
Thank you
