Card: How to set a row type "entities"
I am trying to set up a part of a card to be conditional, listing several entities if the “show more” boolean is selected. The condition works well, but the row itself does not want to show my entities, complaining that “No card type configured”.
Below is my code
type: entities
title: Bathroom
entities:
  - entity: switch.dryer_power
  - entity: button.dryer_remote_start
  - entity: switch.washer_power
  - entity: button.washer_remote_start
  - entity: input_boolean.show_more
  - type: conditional
    conditions:
        state: "on"
    row:
      type: entities
      entities:
        - entity: sensor.dryer
        - entity: sensor.dryer_current_course
        - entity: binary_sensor.dryer_dry_completed
        - entity: sensor.dryer_dry_level
One way that seemed to work was to use “type: simple-entity”, but that had the limitation of allowing only a single entity to show.
Any advice on how this can be solved, please?
Thank you for your time.
You can’t put multiple entities there as far as I know. row is a map, not a list.
row map REQUIRED
type: entities
title: Bathroom
entities:
  - type: conditional
    conditions:
        state: "on"
    row:
  - type: conditional
    conditions:
        state: "on"
    row:
  - type: conditional
    conditions:
        state: "on"
    row:
  - type: conditional
    conditions:
        state: "on"
    row:
Multiple entities can only displayed via type: buttons or custom cards that provide stacks.
There is this option which can give you the likes of:
Where I have the results of two different sensors next to each other.
Code
type: entities
entities:
  - entity: sensor.lounge_multisensor_air_temperature
    type: custom:multiple-entity-row
    secondary_info: last-changed
    entities:
      - entity: sensor.lounge_multisensor_humidity
    show_state: false
  - entity: sensor.ensuite_ms6_air_temperature
    entities:
      - entity: sensor.ensuite_ms6_humidity
    show_state: false
  - entity: sensor.kitchen_ms6_air_temperature
    entities:
      - entity: sensor.kitchen_ms6_humidity
    show_state: false
  - entity: sensor.passage_ms6_air_temperature
    entities:
      - entity: sensor.passage_ms6_humidity
    show_state: false
  - entity: sensor.gym_multisensor_air_temperature
    entities:
      - entity: sensor.gym_multisensor_humidity
    show_state: false
  - entity: sensor.garage_multisensor_air_temperature_2
    entities:
      - entity: sensor.garage_multisensor_humidity_2
    show_state: false
title: House Temps & Humidity
show_header_toggle: false
Many thanks @Olivier1974 , @pedolsky , both of your comments were very useful and allowed me to solve the issue.
You’re welcome and, by the way, I never thought about this idea of a “Show more” input_boolean in the entities card.
Very clever idea.
