🔹 Card-mod - Add css styles to any lovelace card
No need to use/define variables on such a deep level of DOM.
Besides, posting long code distracts users from a solution itself.
But I myself really appreciate an intention to share a successful result with people.
I will give your comment a like!
Myself, I hate the lack of detail often prevalent when perusing threads.
As for the deep level of DOM I arrived at, it was after many hours and the turning point was discovering the online card-mod-helper tool plus the need to remove spaces within the selector. I haven’t discovered (yet) how to shorten it… As for the use of variables, my bad! Will attempt to correct…
Hey,
it is posoble to reduce the gabs in a mini_graph_card?
416037685_7310432232334376_8394963742747464180_n
Card Mod is installed, but i have no idear.
big Thanks Andi
Daniel, the solution you posted is rather not optimal.
Check 1st post → link at the bottom → styles for m-e-r
type: entities
entities:
  - type: custom:multiple-entity-row
    entity: sun.sun
    card_mod:
      style:
        hui-generic-entity-row $: |
          state-badge {
            color: orange;
          div.entity:nth-child(1) state-badge {
            color: cyan;
          div.entity:nth-child(2) state-badge {
            color: red;
    entities:
      - entity: sun.sun
        icon: mdi:car
      - icon: mdi:link
    icon: mdi:account
Ofc, colors of “secondary” icons may be done directly by using a native “styles” option; with card-mod you may make colors templated by jinja.
Also, icon’s color (for the main entity & “secondary” entities) may be also controlled automatically w/o card-mod by theme variables in some cases.
I know grid is less common here and I did not find any fitting examples, so maybe it is not a grid problem.
But I am creating a card with vertical-stack, entities, custom:button-card and markdown.
Card hierarchy is
  • Vertical-stack
    ** Custom:Layout-card (type grid)
    *** Two custom:button-card in the first grid (i.e. first row of vertical-stack)
    *** 5 Entities and 2x5 markdown cards (with custom:config-templater) in the second grid (i.e. second row of vertical-stack)
Unfortunately, there is a gap between the first and second row (two custom:layout-card grids).
In addition, the content of all my markdown cards (populated with custom:config-templater) is aligned top/start instead of center.
Does anybody know where I need to apply my styling to fix these two issues?
Almost. An em is specifically the width of the letter M of the current font at its current size. Similar is ex, which is the height of the letter x. This matters, because a font of size 24pt isn’t just a 2x scaled up version of the 12pt font. In some cases it is, but for well-designed fonts this isn’t the case. So, if you have a UI where different font sizes are used at different screen sizes, using these relative measures scale things in a special non-linear proportion. Otherwise, we could just have stuck to a percentage, but that won’t always look right. Anyway, I thought it would be interesting to know. There was a time I took a lot of interest in typography.
Thanks for the slight correction. Was not aware of the use of em vs ex and why they are named that - every day is a school day! :slight_smile:
How to combine different mods in same card?
I want to change the icon size and secondary text in a tile card, but I cannot seem to do both. When I just do one or the other, it works.
One card mod changes the tile icon size:
card_mod:
  style: |
    ha-tile-icon {
      --mdc-icon-size: 12px;
The other changes the secondary info in the tile card:
card_mod:
  style:
    ha-tile-info$: |
      .secondary {
        color: grey !important;
        font-weight: bold !important;
        visibility: hidden;
      .secondary:before {
        visibility: visible;
        content: {% if is_state('media_player.samsung_ue75ju7000', 'on') %}
         'TV is on'
        {% else %}
         '{{state_attr('climate.floorC82B96A543E8_4_climate', 'current_temperature')}} °C'
        {% endif %}
Simply putting the mods into the same does not work (in this case only the icon size changes):
card_mod:
  style: |
    ha-tile-icon {
    ha-tile-info$: |
      .secondary {
        visibility: hidden;
      .secondary:before {
         'TV is on'
        {% else %}
        {% endif %}
Probably a CSS formatting or syntax issue, right? Have tried seeking help in the CSS documentation, CSS validators and asked ChatGBT, but so far no success? What am I doing wrong?
1st post → link at the bottom → other → combining
Apologies. Not sure what you are referring to. Tried looking at the bottom of the first post for a link called other or combining, but didn’t see one?
There is only 1 link in the end of the 1st post
sorry, found this, which I believe you are ferring to: :small_blue_diamond: Card-mod - Add css styles to any lovelace card - #3907 by Ildar_Gabdullin
But not sure how to apply this? What is wrong in my example?
No, not the link you posted.
Follow that one about “combining”
I started with this one (🔹 Card-mod - Add css styles to any lovelace card - #3905 by Ildar_Gabdullin) but it seemed the other one was the explanation. Tried adding .: | but it seemed to make no difference.
(This also does not work):
card_mod:
  style:
    ha-tile-info$: |
      .secondary {
        visibility: hidden;
      .secondary:before {
         'TV is on'
        {% else %}
        {% endif %}
      ha-tile-icon {
I would suggest to try on simpler examples w/o templates, pseudoclasses etc.
Thanks! This helped me see the indentation error. This works!:
card_mod:
  style:
    ha-tile-info$: |
      .secondary {
        visibility: hidden;
      .secondary:before {
         'TV is on'
        {% else %}
        {% endif %}
      ha-tile-icon {
      --mdc-icon-size: 20px;
Thank you so much for your time,
I’m still not sure exactly what you meant by this…
Assume we have this multi-level structure:
element A → element B → element C → element D
For simplicity - assume that on each level an element has only one child.
Assume we need to apply some property like “color: red”.
We need to go down only to the level (not deeper) where this property is really meaningful (even may be not used yet - but the child element may inherit this property; this is a trick which MAY be useful if the child element is changed in some version of HA).
Means - no need to set the property to the element D if it is sufficient on a level C.
Next, assume this feature (color) may be set by some variable.
I.e. on this level C the color is by default defined as “var(–ha-super-color, #ff00ff)”.
Means - you may set this “–ha-super-color” on the level A - and this will work.
But if there is only ONE level - check a simple example based on your+mine codes:
          state-badge {
            --card-mod-icon-color: orange;
            --card-mod-icon-color: cyan;
           --card-mod-icon-color: red;
No need to use vars here. On this level a property may be used.
I believe I understand now what you were getting at.
I have a question though on a related note: Is there a way to refer to a secondary entity?
config.entity seems to be the primary one but can I refer to the entity in the div.entity.nth-child(2) rather than using 'sensor.[[blind]]_battery_level'?
Summary
card_mod:
  style:
    hui-generic-entity-row:
        state-badge {
          --card-mod-icon: {{ is_state(config.entity,'open')|iif('phu:blind-tilt-open;','phu:blind-tilt-closed','mdi:help-circle') }};
          --card-mod-icon-color: {{ is_state(config.entity,'open')|iif('gold','beige','red') }};
          {% set percentage = states('sensor.[[blind]]_battery_level')|int(0) %}
          {% set r, g, b = 0, 0, 0 %}
          {% if (percentage <= 51) %}
            {% set r = 255 %}
            {% set g = (5.0 * percentage) | round | int %}
          {% else %}
            {% set g = 255 %}
            {% set r = (505 - 4.89 * percentage) | round | int %}
          {% endif %}
          --card-mod-icon-color: {{ "#%0x" | format( r * 0x10000 + g * 0x100 + b * 0x1 ) }};
PS I just learned about [details="<some text>"] and have compressed my original post considerably!
Yet you are still using “-card-mod-icon-color” vars.
I would not recommend using “iif” since it may give wrong results.
Even there is an issue in core.
Besides, I do not recommend using templates INSIDE a property definition. You will see what I mean if search my posts with templates in card-mod.
As for using config-entity-like variable in m-e-r - it is possible like “config.entities[…].entity”.
