šŸ”¹ Card-mod - Add css styles to any lovelace card
Hi all, hoping someone can point out if there have been changes in the last few months of if I’ve done something wrong.
I’m scraping data from a website and want to display just the relevant name and number. The code shown previously hid the state icon (eyeball) but it hasn’t worked for a few months now.
What should it look like? Thanks in advance.
This will work…
        card_mod:
          style: |
            ha-card {
              background: none !important;
              border: none !important;
Just ensure you are on card_mod version 3.4.4.
Is there a way to make date fields, hour and minutes, less wide and closer together ? I managed to configure many constants following @Ildar_Gabdullin post, but I’m not able to change the width and position of these fields. The following is a screen capture of my form:
Many thanks!
Please post your card code.
@LiQuid_cOOled The entity is a variable in my main code, which I use with different types, and the formatting code, applied for the ā€œinput_datetimeā€ example is the following one:
        entities:
          - entity: "input_datetime.myshade_open_time"
            card_mod:
              style:
                ha-time-input $ ha-base-time-input $:
                  ha-textfield:
                    $: &ref_style_no_underline_time |
                      .mdc-line-ripple::before,
                      .mdc-line-ripple::after {
                        border-bottom-style: none !important;
                      .mdc-text-field {
                        height: 20px !important;
                  ha-select $: *ref_style_no_underline_time
                hui-generic-entity-row $: |
                  state-badge {
                    display: none;
                  .info {
                    display: none;
                  .text-content {
                    font-size: 14px;
                ha-textfield $: |
                  .mdc-line-ripple::before, .mdc-line-ripple::after {
                  .mdc-text-field {
                  .mdc-text-field__input {
                    align-self: center;
                  span#label {
                    display: none;
                ha-select $: |
                  .mdc-select__anchor {
                    height: 25px !important;
                  .mdc-select__selected-text-container {
                    align-self: start;
                  span#label {
                    display: none;
                ha-select $ mwc-menu $: |
                  mwc-list {
                    max-height: 400px;
                  ha-select {
                    height: 25px;
                  :host {
                    --mdc-menu-item-height: 60px;
                    --secondary-text-color: var(--primary-text-color);
                    --paper-item-icon-color: silver;
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              border: none;
              background-color: transparent;
Many thanks
Maybe a little late for my question, but where exactly do you put that card mod code for a tabbed card in your card so it works?
I tried plenty of different ways but none seems to work. I have other card mod things running and those seem to work. I tried to use the FX inspector to get a clue but wasn’t successfull.
So for I have this but the card remains totally unchanged.
type: custom:tabbed-card
options: {}
card_mod:
  style:
    tabbed-card $:
      mwc-tab:
          mwc-tab-indicator $: |
            .mdc-tab-indicator__content--underline {
              border-color: red !important;
            .mdc-tab {
              min-width: 40px !important;
              background: yellow !important;
            .mdc-tab--active {
              background: lightgreen !important;
tabs:
  - card:
      type: entities
      title: Battery States - ClimateSensors
      entities:
        - entity: sensor.shellyht_gamingroom_battery
          name: GamingRoom (PwrSpply)
        - entity: sensor.shellyht_garage_battery
          name: Garage (PwrSpply)
        - entity: sensor.shellyht_hall_battery
        - entity: sensor.shellyht_kitchen_battery
          name: Kitchen (PwrSpply)
        - entity: sensor.shellyplusht_bathroom_battery
        - entity: sensor.shellyplusht_homecinema_battery
        - entity: sensor.shellyplusht_laundry_battery
        - entity: sensor.shellyplusht_sleepingroom_battery
        - entity: sensor.shellyplusht_library_battery
        - entity: sensor.shellyht_livingroom_battery
          name: Living Room (PwrSpply)
    attributes:
      label: false
      icon: mdi:thermometer-water
Check my examples again, it needs mod-card.
much to my surprise/shame I just realized I can not find a way to card-mod the .card-header in a regular markdown card…
      - type: markdown
        title: Batterijen onder alert
        card_mod:
          style: |
            .card-header {
               background: var(--background-color-off) !important;
               font-weight: 400 !important;
               font-size: 20px !important;
               color: var(--text-color-off) !important;
               padding: 0px 12px !important;
               margin: 0px 0px 16px 0px !important;
            ha-card {
              --card-text-align: start;
              /*color: var(--primary-color);
              background: rgba(from var(--primary-background-color) R G B /0.4);*/
              box-shadow: var(--box-shadow);
is all I need to do, and I want to mimic the regular card-headers I use in almost any card…
What I normally do is use a vertical-stack and stack a header card and a content card. But we should be able to customize the card-header shouldnt we…?
in following screen you see what I get and what I want (the second card)
( I only discovered because I experimented using the template markdown in the new View header, then couldn’t find a way, and tested if this was also not working in side the regular view section. Which is the case…
btw, doing this inside the Inspector pane works alright. proving .card-header is the correct element:
Start with this…
    card_mod:
      style:
        ha-time-input $ ha-base-time-input $: |
          #hour {
             width: 30px;
             margin-right: -3px;
          #min {
              width: 30px;
              margin-left: -1px;
Yes, this was missed in Markdown tutorials here. Will check it in a week I hope - unless you sort it out yourself.
Need some help, I had this code working and the background was black, now after updating HomeAssistant it is more transparent and does not overlap the other cards in the background.
type: custom:mod-card
card_mod:
  style: |
    @media (min-width:180px) {
      ha-card {
        z-index: 1;
        position: fixed;
        bottom: 10px;
        left: 10px;
        width: calc(100% - 20px);
        background: black;
        border-radius: 100px;
        padding: 5px;
    @media (min-width:800px) {
      ha-card {
        width: calc(60% - 30px);
        left: calc(20% + 43px);
card:
  type: grid
  square: false
  columns: 5
  cards:
    - type: custom:button-card
      icon: mdi:home
      tap_action:
        action: navigate
        navigation_path: /dashboard-rounded/home
      styles:
        icon:
          - width: 24px
          - color: white
        img_cell:
          - width: 50px
          - height: 50px
        card:
          - background: none
          - padding: 0
      icon: mdi:lightning-bolt
      tap_action:
        action: navigate
        navigation_path: /dashboard-rounded/Energia
      styles:
        icon:
          - width: 24px
          - color: white
        img_cell:
          - width: 50px
          - height: 50px
        card:
          - background: none
          - padding: 0
      icon: mdi:car
      tap_action:
        action: navigate
        navigation_path: /dashboard-rounded/Garagem
      styles:
        icon:
          - width: 24px
          - color: white
        img_cell:
          - width: 50px
          - height: 50px
        card:
          - background: none
          - padding: 0
      icon: mdi:server
      tap_action:
        action: navigate
        navigation_path: /dashboard-rounded/status
      styles:
        icon:
          - width: 24px
          - color: white
        img_cell:
          - width: 50px
          - height: 50px
        card:
          - background: none
          - padding: 0
      icon: mdi:cog
      tap_action:
        action: navigate
        navigation_path: /dashboard-rounded/config
      styles:
        icon:
          - width: 24px
          - color: white
        img_cell:
          - width: 50px
          - height: 50px
        card:
          - background: none
          - padding: 0
Edit: Added photo of how I had it.
Edit2: Now
I will try, but havent found it yet, if I do, Ill reply again :wink:
dont forget…
In your shoes I would test with a Grid containing a few stock Entity cards and with static not-mediaquery-dependent styles. Currently your code contains plenty of stuff distracting from the main issue. Besides, make sure that you are using the latest card-mod 3.4.4.
card_mod:
  style:
        .card-header {
At least in my version. After all this year you should see if an element is inside shadow-root and if not, shouldn’t you? :wink:
yes, and that is what I tested too. but maybe fluked because of the rest of the mod or type, let me try again
edit
      - type: markdown
        card_mod:
          style:
                .card-header {
              ha-card {
does Not mod the .card-header
(using 3.5.0 here, but I doubt that would change anything in this matter, as its changes didnt touch anything going on in this particular config)
Ive even hazarded a wild experiment doing
        card_mod:
          style:
              .card-header {
which remained fruitless also.
so I am back to my workaround:
Header workaround
header:
  layout: center
  badges_position: bottom
  card:
    type: vertical-stack
    card_mod: !include /config/dashboard/card_mods/stack_card_gap_shadow.yaml
    cards:
      - type: heading
        heading: Batterijen onder alert
        heading_style: title
        card_mod:
          class: class-section-heading
      - type: markdown
        card_mod:
          style: |
            ha-card {
    #     text_only: true
        content: >
          {% set b = label_entities('batterij') %}
          {% set alert_level = states('input_number.battery_alert_level')|int %}
          {% set val = b | map('states')| map('int',-1) %}
          {% set nam = b | map('state_attr', 'friendly_name') %}
          {% set z = zip(nam, val)| selectattr(1, 'lt', alert_level)|sort(attribute=1) %}
          {{ z | map('join', ': ') | join('% \n') }}%
separate post, because I just had a brainwave for 3.5.0 card_mod…
if you use 3.4.4, follow Arganto’s post above
click to reveal 3.5.0 mod
      - type: markdown
        card_mod:
          style:
            ha-card:
                .card-header {
              ha-card {
makes it happen
can leave out a few !important’s
        card_mod:
          style:
            ha-card:
                .card-header {
                   background: var(--background-color-off);
                   font-weight: 400;
@Ildar_Gabdullin tagging you because of earlier promise
can also confirm this to work inside the header: of the view
That’s it as you know. There you don’t start from ha-card. And have to access differently. As you know. :wink:
And as long no one besides you is using this version, it is somehow confusing for others, I would say, if the want to rebuild, what you are asking.
Ive edited the post above to make it a bit more obscure, and point to your post, that Ildar could add to the Fantastic post.
(I am still hoping Thomas will update and bring back what was taken from us going down to 3.4.4…) (I cant go back, well, I could, but it would be a shame if shortly after that, I would have to re-edit again all over…) so it’s a devilish dilemma…
i’m using last version, already reinstalled a older version and inst fixed. Its after last HA update and Core
@LiQuid_cOOled Yes this is working very well! Many thanks! Now my problem is that I don’t know how to integrate your code with mine… Sorry for my lack of knowledge. The fiollowing is my code:
                  ha-textfield:
                      .mdc-text-field {
As you can see, the first line is ā€œha-time-input $ ha-base-time-input $:ā€ and it doesn’t end with ā€œ|ā€. So my question is how to add:
                  #hour {
                    width: 30px;
                    margin-right: -3px;
                  #min {
                    width: 30px;
                    margin-left: -1px;
Thank you very much!
