Card-mod - combined usage of icon- and background color change
What would be the result in these two cases?:
Default theme
Midnight theme
You have lost me on what you are trying to achieve…
Well, look at the screenshots above.
The left card switches his background to lightgreen and should switch his background back to the themes default. This is the background of the two cards (middle and right).
When using the default theme (the bright one): RGB 255,255,255
When using the midnight theme: RGB 66,72,84
Ok I’m done for today. You are not being clear about the theme settings and the code I provided will work if you identify the standard colors of the theme.
Thanks anyway
Best of luck
