Card Mod Refresh
Hello! I’m very new to home assistant and I found card mod integration. I’ve done some useful things with it but I notice that half the time when my dashboard loads on the home assistant app, the card mods are not loading. Am I doing something wrong or is there something I didn’t do correctly. Some times a refresh helps and sometimes it doesn’t. Please help me! Thank you!
Suggest to use the maintained UI eXtension integration instead. card-mod needs careful managment of resource URLs as per the readme. That need goes away with UIX. Read FAQ on migrating from card-mod etc.
@dcapslock thank you! That worked perfectly! Really appreciate it!
Can I ask you another question. In Hubitat I used voice monkey to make Alexa play a sound from a file saved in drop box. Do you have any idea how I can play those sounds on my Alexa’s in home assistant without voice monkey? Everything I’ve tried keeps telling me that direct music streaming is not supported.
Not sure. I don’t have Alexa. Check out any Alex intgreation and follow docs.
