Card_mod with mushroom-template-card
Hello everyone,
I’m experimenting a bit with the new card_mod features and would like to display the ring around the icon from 0 to 360 degrees in proportion to the brightness. The color of the ring should also be displayed in proportion of the brightness from dark yellow (1%) to bright yellow (100%). There should be no ring, if the light is off.
Has anyone already implemented such a solution or something similar? I would be very happy if this could be shared here.
type: custom:mushroom-template-card
primary: Tischleuchte
multiline_secondary: true
icon: mdi:lightbulb
tap_action:
  action: toggle
hold_action:
  action: more-info
entity: light.ikea_tischleuchte_kellerflur
secondary: |-
  {% if states(config.entity) =='on'%}
    {{'ein: '}}{{as_timestamp(states[config.entity].last_changed)|timestamp_custom('%H:%M')}} Uhr
  {%else%}
  {{'aus' }}
  {%endif%}
color: |2-
        {% if is_state(config.entity, 'on') %}
        {{ state_attr(config.entity, "rgb_color")[0] }}
        {{ state_attr(config.entity,"rgb_color")[1] }}
        {{ state_attr(config.entity, "rgb_color")[2] }}
        {%else%}
         {{'#7E7E7E'}}
        {% endif %}
vertical: true
features_position: bottom
card_mod:
  style:
    ha-tile-icon$: |
      .container:before {
        display: none;
      .container:after {
        content: "";
        position: absolute;
        inset: 0;
        mask: radial-gradient(farthest-side, transparent calc(100% - 4px), #000 0);
        background: radial-gradient(farthest-side, var(--amber-color, #0000FF) 94%, transparent) top/4px 4px no-repeat,
                    conic-gradient(transparent 30%, var(--amber-color, #0000FF));
        animation: spin 2s ease infinite;
        will-change: transform;
      @keyframes spin {
        0% { transform: rotate(0deg); }
        100% { transform: rotate(360deg); }
      ha-card {
         margin-top: 0px;
         margin-bottom: 0px;
         height: 90px !important;
         # border: none !important;
          --mdc-icon-size: 20px;
          --ha-card-border-radius: 0px;
          --ha-card-border-color: #3c3c3c;
          --ha-card-border-width: 1px;
      ha-tile-icon {
         --mdc-icon-size: 25px;
         --tile-icon-size: 30px;
      #info {
        --tile-info-primary-font-size: 12px;
        --tile-info-secondary-font-size: 10px;
        --tile-info-primary-color: orange;
        --tile-info-secondary-color: lime;
