[Card] Multi Air Conditioner Card – Smart AC control with automation & modern UI
:snowflake: Multi Air Conditioner Card
Not just a UI — a complete multi-room HVAC control system for Home Assistant
Meet Multi Air Conditioner Card — a next-generation Lovelace card designed to behave like a real-world HVAC system, not just a dashboard widget.
Built from the ground up with performance, UX, and real automation logic in mind.
:house: True Multi-Room Architecture (Not Just Tabs)
Control up to 8 rooms simultaneously, each fully independent:
• Temperature & humidity
• Power consumption
• HVAC modes & fan/swing logic
• Timers & runtime state
This card doesn’t just display rooms — it thinks per room.
:high_voltage: 3 Interfaces in 1 Card — Fully Synced
Switch instantly between 3 modes depending on your use case:
Full Mode → Rich UI, full monitoring & control
Lite Mode → Clean, faster interaction
Super Lite → Ultra-minimal, mobile-first
All modes share the same state & logic → no desync, no reload needed
:bullseye: Smart Behavior That Feels “Alive”
Designed to behave like a real system, not a static UI:
• Remembers last active room (even after reload)
• Restores previous HVAC state automatically
• Skips offline/unavailable devices intelligently
• Auto-recovers instantly when devices come back online
• “Turn All Off” only affects available devices
:satellite_antenna: Real-Time Monitoring & Fault Handling
• Visual OFFLINE detection across all UI modes
• Disabled controls when device is unavailable
• Instant recovery without reload
• Consistent behavior across Full / Lite / Super Lite
:snowflake: Advanced HVAC Control
Per-room full control:
• Cool / Heat / Dry / Fan modes
• Temperature adjustment
• Fan speed cycling (Auto → High)
• Swing / airflow direction (auto-detect supported modes)
Includes animated feedback system with particle effects per HVAC mode.
:thermometer: Real Environment Integration
Each room supports:
• Temperature sensor override
• Humidity sensor
• Power consumption tracking
Plus global sensors:
• Outdoor temperature
• Humidity
• PM2.5 (air quality)
:stopwatch: Persistent Timer System (Not Just UI)
• Schedule ON/OFF with minute precision
• Independent timers per room
• Countdown display in real-time
• Survives reload (stored in localStorage)
:artist_palette: Advanced UI/UX Engineering
• Auto-scale layout (mobile & desktop perfect)
• Gradient themes + custom color system
• Animated temperature dial with dual-layer logic
• Smooth transitions & interaction feedback
• Super Lite popup effects (Normal / Effect / Wave)
:globe_with_meridians: Multi-language Support (11 languages)
:vietnam: Tiếng Việt / :united_kingdom: English / :germany: Deutsch / :france: Français / :netherlands: Nederlands
:poland: Polski / :sweden: Svenska / :hungary: Magyar / :czechia: Čeština / :italy: Italiano / :portugal: Português
:check_mark: Real country flags in selector
:check_mark: Fully localized UI
:gear: Deep Customization
• Colors, gradients, themes
• Toggle any UI element on/off
• Flexible layout per mode
• Works with any climate entity
• No dependencies — fully standalone
:rocket: Installation
HACS (Recommended)
  1. Add custom repository:
    GitHub - doanlong1412/Multi-Air-Conditioner-Card · GitHub
  2. Install via HACS → Frontend
  3. Reload browser
Manual
url: /local/multi-air-conditioner-card.js
type: module
⚙️ Basic Usage
type: custom:multi-air-conditioner-card
entities:
  - climate.living_room
  - climate.bedroom
📸 Preview
🎬 Demo:
https://github.com/doanlong1412/Multi-Air-Conditioner-Card/blob/3ea69a0e89b393b2383f337a477b627a970a8f8a/assets/preview.gif
🖼️ Screenshot:
https://github.com/doanlong1412/Multi-Air-Conditioner-Card/blob/3ea69a0e89b393b2383f337a477b627a970a8f8a/assets/preview.png
🔗 GitHub
⭐ Support
If you find this useful, please give it a star on GitHub — it helps the project grow.
❤️ Future Development
More advanced features are coming:
• Smarter automation logic
• Better central AC support
• Performance optimizations
• More UI modes
Feedback, ideas, and issues are always welcome!
Why is it so common in the last times to share UIs, cards and projects without showing any pictures and Screenshots here? If I would be able to create those and want to promote or proudly share my work here, the first thing I would do is to show how it look like.
robot.kantam
1m
nice work man…by far this is most compact yet has all elements i need for my AC control. UI is also beautiful.
i have questions…how to remove greeting in super lite mode? and power sensor seems not saved, it is back to empty after i select sensor for power monitoring and click save
