Hi! I have some issues with cleverio PF100 where most of the sensors/settings is missing. Currently only the manual feed exists but the api exposes multiple data points. I am mostly interested to fetch and update the the meal_plan
. Currently working on a separate UI to modify the base64 encoded string.
Anyone who can help me? The the local tuya (GitHub - make-all/tuya-local: Local support for Tuya devices in Home Assistant) already have that implemented if it helps, but I would like to avoid installing both the official tuya and local tuya.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.7.3",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Stockholm",
"os_name": "Linux",
"os_version": "6.6.31-haos-raspi",
"supervisor": "2024.06.2",
"host_os": "Home Assistant OS 12.4",
"docker_version": "26.1.4",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"Tuya",
"zlinoliver",
"frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-device-sharing-sdk==0.1.9"
"is_built_in": true
"setup_times": {},
"data": {
"endpoint": "https://apigw.tuyaeu.com",
"terminal_id": "1721672406856ZZD6Tw",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"id": "bfd0273e59494eb34esvrx",
"name": "Cleverio PF100",
"category": "cwwsq",
"product_id": "wfkzyy0evslzsmoi",
"product_name": "Cleverio PF100",
"online": true,
"sub": false,
"time_zone": "+02:00",
"active_time": "2024-05-08T15:27:53+00:00",
"create_time": "2024-05-08T15:27:53+00:00",
"update_time": "2024-05-08T15:27:53+00:00",
"function": {
"meal_plan": {
"type": "Raw",
"value": {}
"manual_feed": {
"type": "Integer",
"value": {
"unit": "",
"min": 1,
"max": 20,
"scale": 0,
"step": 1
"factory_reset": {
"type": "Boolean",
"value": {}
"light": {
"type": "Boolean",
"value": {}
"status_range": {
"meal_plan": {
"type": "Raw",
"value": {}
"manual_feed": {
"type": "Integer",
"value": {
"unit": "",
"min": 1,
"max": 20,
"scale": 0,
"step": 1
"factory_reset": {
"type": "Boolean",
"value": {}
"battery_percentage": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"charge_state": {
"type": "Boolean",
"value": {}
"feed_report": {
"type": "Integer",
"value": {
"unit": "",
"min": 0,
"max": 20,
"scale": 0,
"step": 1
"light": {
"type": "Boolean",
"value": {}
"status": {
"meal_plan": "fwQAAgF/CQACAX8PAAIBKBIAAQB/FQADAQ==",
"manual_feed": 1,
"factory_reset": false,
"battery_percentage": 70,
"charge_state": false,
"feed_report": 3,
"light": true
"home_assistant": {
"name_by_user": null,
"disabled": false,
"entities": [
"disabled": false,
"entity_category": null,
"device_class": null,
"original_device_class": null,
"icon": null,
"original_icon": null,
"unit_of_measurement": "",
"state": {
"entity_id": "sensor.cleverio_pf100_senaste_mangd",
"state": "3.0",
"attributes": {
"state_class": "measurement",
"friendly_name": "Cleverio PF100 Senaste m\u00e4ngd"
"last_changed": "2024-07-23T19:00:20.200686+00:00",
"last_reported": "2024-07-23T19:00:20.200686+00:00",
"last_updated": "2024-07-23T19:00:20.200686+00:00"
"disabled": false,
"icon": null,
"unit_of_measurement": null,
"state": {
"entity_id": "number.cleverio_pf100_mata",
"state": "1.0",
"attributes": {
"min": 1.0,
"max": 20.0,
"step": 1.0,
"mode": "auto",
"friendly_name": "Cleverio PF100 Mata"
"last_changed": "2024-07-22T18:20:08.488911+00:00",
"last_reported": "2024-07-23T19:00:20.201324+00:00",
"last_updated": "2024-07-22T18:20:08.488911+00:00"
"set_up": true,
"support_local": true
