I am stuck on version 2021.10.x, because I had to roll back an unsuccessful update back then. How should I catch up? Install latest or go through with all the versions to be sure that all update scripts will be run in sequence?
I would go thru each version and fix all the breaking changes for each before moving to the next (if there are any - maybe there won’t be).
if not you won’t easily know where the problem might be.
