Hey Guys,
I bought the following CC2531 from Amazon and went through the steps of flashing it using Raspberry Pi successfully (or I think so)
When it comes to configuring zigbee2Mqtt I am stuck on the part where you are supposed to change the following part in the configuration:
serial:
port: /dev/ttyaCM0
I saw a video where you can go into supervisor/system and under host select hardware which would show you a list of devices but I am getting a HUGE list when I do that and I tried removing the USB and restarting the system and then checking again but the list doesn’t change at all.
Have I not flashed my USB correct? This is what I see under device_manager of the computer:
Am I even suppose to change that part of the configuration?
