Hi everyone!
I’m having trouble controlling the brightness and color temperature of my CCT COB LED strip (608 LEDs)
I’m using:
ESP32 + ESPHome
2x IRLB4132 MOSFET-Y
The problem is that when I change the color temperature, I see the strip’s brightness drop slightly, and it only returns to normal once the new color temperature is set.
My YAML currently looks like this:
output:
- platform: ledc
pin: GPIO25
frequency: 1220Hz
zero_means_zero: true
- platform: ledc
pin: GPIO26
frequency: 1220Hz
type: float
write_action:
- output.set_level:
level: !lambda |-
if (state <= 0.0f) return 0.0f;
return powf(state, 0.833f);
type: float
write_action:
- output.set_level:
level: !lambda |-
light:
- platform: cwww
warm_white: pwm_cct_warm
cold_white: pwm_cct_cold
warm_white_color_temperature: 2700K
cold_white_color_temperature: 5000K
constant_brightness: true
gamma_correct: 1.0
default_transition_length: 800ms
restore_mode: RESTORE_AND_ON
Thanks in advance for any help. Have a nice day, everyone. ![]()
