I have a CCT PWR , and I want to connect 2 wire white LED lamp and Dimm the light.
HA “Zigbe Home Automation find the PWR, and can connect to the “C” and tun the LED lamp on / Off
but even if I change the Color Temperature the light does not change , when I connect the LED to the “W” on the PWR I get no light , it seems as Zigbee default control has no dimm function and the Color temp. does not change , I have looked at " H-bridge Light” but it is using ESPHome , Any Idea ?
I found the solution, I was looking at the wrong interface in HA
when I connect my 2 wire LED to + and W on the PWR, I can now do on /off, DIMM and also change from warm to cold white, all good
