I have been running Claude Code heavily for the last few months and got tired of alt-tab-ing to a terminal to check how close I was to the 5h rate limit. The Anthropic dashboard is per-request, not per-window, so it never told me what I actually wanted to know: "am I about to get rate-limited in the next 20 minutes?"
So I built ccusage-mqtt — a single Python process that publishes Claude Code usage to MQTT, and Home Assistant auto-discovers a device with 15 sensors including a mood enum (idle / normal / active / heavy) calibrated from the same burn-rate thresholds the Clawdmeter ESP32 firmware uses (github.com/HermannBjorgvin/Clawdmeter).
drag the dashboard-preview.gif here from docs/assets/ in the repo so it uploads as an attachment — don't paste the GitHub URL ]
What you get
A single Claude Code Usage device with:
mood—idle/normal/active/heavy(the cardinal sensor — drives a Lovelace picture-entity card with mood-matched art)session_pct/session_reset_minutes/session_status— Anthropic's 5h window (Pro / Max)weekly_pct/weekly_reset_minutes/weekly_status— Anthropic's 7d window (Pro / Max)burn_rate_pct_per_min— smoothed over a 4-min ring buffertime_to_limit_minutes— derivedtokens_used/tokens_per_hour/spend_so_far_usd/spend_per_hour_usd— fromccusage(github.com/ryoppippi/ccusage)block_elapsed_pct— how far into your current 5h block
Pro/Max and Enterprise plans both supported (Enterprise returns a different ratelimit-header schema — the parser handles both via a fallback chain).
Why MQTT, not a HACS integration
Two reasons:
- The publisher has to run where Claude Code runs — it reads
~/.claude/.credentials.jsonfor the OAuth token. Most HA-OS users run HA on a separate box from their dev machine, so a HACS integration would have to do remote credential plumbing. MQTT lets the publisher live on the dev machine and the data flow into HA over the network you already have. - No separate Anthropic API key. The publisher reuses Claude Code's existing OAuth token (with auto-refresh), so quota measurements reflect the actual plan you're on, not a separate dev-API quota.
Install (60 seconds)
git clone https://github.com/george-vice/ccusage-mqttcd ccusage-mqttpipx install ../setup.sh
Or use the Docker path — bundles Node + ccusage + Python in one image. Install instructions and a copy-paste Lovelace YAML are on the landing page: george-vice.github.io/ccusage-mqtt
Where it goes next
- A dedicated Lovelace card that watches
sensor.claude_code_usage_moodand renders the matching pixel-art frame (HACS-shippable once it exists) - A blueprint exchange listing for "alert when mood stays heavy for N minutes" (already shipped in the repo, posting separately)
It's MIT, v0.2.0 just tagged. Happy to answer questions about the architecture, the OAuth-token-vs-API-key tradeoff, or the Enterprise header parser. Feedback / ideas / PRs all welcome.
