Ceiling fan based on counter value and Presence
I’m trying to automate my ceiling fan based on a counter. If the counter is below 5 and no Presence is detected then wait 5 minutes and turn off , if over 5 then wait 20 minutes however this doesn’t seem to be happening. I can see the counter is working correctly so it must be my logic
alias: Ensuite Ceiling Fan
description: ""
triggers:
  - trigger: state
    entity_id:
      - binary_sensor.shower_2_presence
    to: "on"
  - trigger: state
    entity_id:
    to: "off"
    for:
      hours: 0
      minutes: 5
      seconds: 0
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Presence Home
        sequence:
          - type: turn_on
            device_id: cee4b35b0939f91ce077ca05a906a5f6
            entity_id: 582dedd642599d97da8e8b0dfaac907f
            domain: switch
      - conditions:
            id:
              - Presence Away
          - condition: numeric_state
            entity_id: counter.ensuite_shower_counter
            attribute: "0"
            below: 5
        sequence:
          - delay:
              hours: 0
              minutes: 5
              seconds: 0
          - type: turn_off
            domain: switch
      - conditions:
            id:
              - Presence Away
            attribute: "5"
            above: 5
            below: 100
        sequence:
          - delay:
              hours: 0
              minutes: 20
              seconds: 0
          - type: turn_off
            domain: switch
mode: single
Your code is near unreadable, edit your post and mark it up as code.
