Hi, I recently bought this device (REV-LIGHT - Geconnecteerde lichtschakelaar - DiO Connect) a wifi switch by Chacon. And it work great with the Dio One app. As it’s wifi, I’m looking to integrate it in HA. But without success…
I don’t see a lot off topics about this reference.
Thanks a lot !
Hi, I also have a Connected Shutter Switch DiO Connect (Connected Shutter Switch DiO Connect) and would also appreciate an integration in home assistant.
Have you had any luck?
I’m also interested.
I was controling those shutter with RFXCOM and it worked perfectly, but I recently moved and my house is too big for 433mhz cover. That’s why I installed dio one app and need to connect it to ha.
I have some DIO REV-Light and REV-Shutter. I implemented an integration that is to be merged in homeassistant core as an integration. See : Add new integration for Dio Chacon cover devices by cnico · Pull Request #116267 · home-assistant/core · GitHub
I use it in my homeassistant installation as a temporary custom integration awaiting it to be integrated in a future release of homeassistant.
Wait and see
Hi cnico,
I installed the integration and logged in with accountname and pw but it doesn’t find my Dio devices.
Does it automatically detect the devices or is there something more to configure?
Thanks in advance.
Hi @Jan_F,
The DIO integration is now in homeassistant since version 2024.8. I use it every day to automate my covers and it works very well.
For switches (plugs and walls for lights), it will be available in 2024.9 version.
If it finds no DIO devices and you have no errors in the logs, it means that you have devices that are not supported by now.
If it is cameras or doorbell for exemple, I do not plan to implement it as I do not have such devices and it is quite complex.
After upgrading to 2024.9 version, your switch devices should appear automatically.
If it is not the case, please, tell me which devices it is and I will be able to investigate it if you share me temporarily your dio account.
I have to plugs. So not yet supported?
I’ll waot a bit longer.
I now use IFTTT PRO for some automations but want to get rid of that now that I have HA.
2024.9 will be released tomorrow. You don’t have much longer to wait.
I updated to 2024.9 today and it works great for my switches.
What about you @Jan_F ?
Just update and they are visible
