Change binary sensor device class in web UI
I’ve recently installed Home Assistant and have integrated deCONZ with various devices. And my door and window sensors all have square icons that are either filled or unfilled depending on sensor state. If I understand it correctly, the icon will automatically be changed if I define the door and window sensors as door and window device classes.
But how can I set the device classes for the binary sensors in the web UI? Is using customization YAML files the only way?
You can use customize in the UI, I believe. Configuration > Customization?
Thanks, you’re absolutely correct.
I was searching this for over half an hour, and right after posting on the forum I found this: https://www.home-assistant.io/docs/configuration/customizing-devices/ :slight_smile:
