I’ve been unable to find a way to change the color of an animimg widget that uses MDI icons from anything other than the default black.
I’ve tried image_recolor with no effect. I was also thinking that I may be able to apply the color at the time of upload via the image: section, but I’ve tried BINARY and GRAYSCALE, again no good.
Any help would be appreciated! I’m almost at the ‘save each frame as a PNG with the correct color and size’ stage, very inelegant.
Thanks @zoogara - but then I’d also have to set up an Interval component to take care of the frame calls… doable of course, and if the animimg/MDI icon combo simply doesn’t support color-changing from black, which I can’t really believe, it might be the way forward…
