I have an existing dashboard nothing sophisticated. I have a climate section that contains 5 thermostats connected via a Hubspace integration. Yesterday I applied recently released upgrades. Now my thermostats appear to be reporting temp and settings as C with F labels. For example physical thermostat displays 71f and home assistant displays 22f. Anyone have a clue how I can get the system to report correctly. I am on a raspberry pi 5.
Click on the entity, then click the gear.
You should be able to set parameters there.
My system has been working correctly for over a year. My question was whether theee was a change recently which changed the behavior of the system. I was concerned about unadvertised changes which could have changed more than the way one component operated. The question was about change control. I am concerned about a system that will break things without change controls and adequate testing.
They detail every change inthe release notes and it us up tk the user to review.
But which hubspace integration… This one?
If so you probably need to ask the integration author
Or better yet, check if the issue has already been reported a month ago with no reply from the maintainer.
