Change Default Server for app on Mac os
I’m a newb, I tried searching, reading docs and asking Perplexity for help but I can’t find a fix for a simple problem. I switched from a Rasp pi server to HA Green and now I’ve switched back. Both servers show up in the SERVERS tab in Preferences for the Mac os version of the HA app, though the HA green one is not connected. For any restart of the HA app it looks for the HA green server and can’t find it. I have to open preferences, select the active Rasp Pi server and then it loads and works normally. the two servers have different IP addresses xx.130 and xx.160 with .160 being the active one. I suspect there’s a simple way to either change the default or delete the inactive server, but I can’t find it. Perplexity offered several CLI options, none of which worked and all were a bit spooky for a newb and inexpert linux user to play with. Your insight would be appreciated.
