Change entinity in Node-RED or IRL
Hello.
I´m new to node-red so this might be a noob-question. Sorry in advance.
The case is following:
I have a manual setpoint which controls the heating setpoint in a room. I also have a “helper” entinity in Home Assistant that adjusts the same setpoint. (The setpoint tagg is adjusted on BACNet on the same priority,)
What I´m trying to do is when I adjust the manual setpoint, I want the feedback to adjust the setpoint on the same entinity in HomeAssistant.
I guess there is an easy way to do this, but I have tried a couple of blocks, including “call services”. But just ending in an never ending loop.
The only thing that works the way I want is to use a dashboard numeric-block. But I want to use my helper :slight_smile: Does anyone have a quick-fix for this matter?
Glad for any tips :slight_smile:
I’m not familiar with your type of climate control. This is how you would use an input number and a climate entity in HA to change the temp.
[{"id":"6bcc3e0fdb1bbbd3","type":"inject","z":"f80b6c338afd5483","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":820,"wires":[["6f7e07a386bbbb8c"]]},{"id":"6f7e07a386bbbb8c","type":"api-current-state","z":"f80b6c338afd5483","name":"","server":"","version":2,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"input_number.number","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":550,"y":820,"wires":[["5952b9c942e2cea8"]]},{"id":"5952b9c942e2cea8","type":"api-call-service","z":"f80b6c338afd5483","name":"","server":"","version":3,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.t9_thermostat","data":"{\"temperature\":\"{{payload}}\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":820,"wires":[[]]}]
