Is there a way to automatically change entity_id for some entities e.g. via script?
I’m a bit tired to do it manually for the tenths of devices via Web UI every time I connect my aqara hub to the freshly installed HA. I’d like to refer them as binary_sensor.window_kitchen
instead of binary_sensor.door_window_sensor_158d000155f07b
I’ve found another way to automate it - there is a file .storage/core.entity_registry
where entity_id can be altered, then after restart HA will use the new values. It seems a good idea to make changes while HA is stopped to avoid conflicts.
Many thanks! Will check it as well.
