Hi there the if statemen for the fan change direction is not working
remote_receiver:
pin:
number: GPIO15 #D15
inverted: true
dump: nec ##el log mostrará sólo los códigos de NEC que aparezcan
on_nec:
then:
## Comandos del ventilador #################
- if:
condition:
- lambda: return (x.command==0xE01F); # ON/OFF fan
then:
- fan.toggle: ventilador_techo_dormitorio
- switch.toggle: switch_ventilador_techo_dormitorio
- if:
condition:
- lambda: return (x.command==0xF807); # fan direction
then:
- fan.turn_on:
direction: !lambda |-
if (id(ventilador_techo_dormitorio).direction=="forward") {
return reverse;
} else {
return forward;
- switch.turn_on: switch_ventilador_techo_dormitorio
Error says:
/config/esphome/luz-ventilador-dormitorio.yaml: In lambda function:
/config/esphome/luz-ventilador-dormitorio.yaml:306:49: error: no match for 'operator==' (operand types are 'esphome::fan::FanDirection' and 'const char [8]')
306 | if (id(ventilador_techo_dormitorio).direction=="forward") {
| | const char [8]
/config/esphome/luz-ventilador-dormitorio.yaml:307:16: error: 'reverse' was not declared in this scope
307 | return reverse;
/config/esphome/luz-ventilador-dormitorio.yaml:307:16: note: suggested alternatives:
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/algorithm:85,
from src/esphome/core/optional.h:19,
from src/esphome/components/socket/socket.h:5,
from src/esphome/components/api/api_frame_helper.h:12,
from src/esphome/components/api/api_connection.h:5,
from src/esphome.h:3,
from src/main.cpp:3:
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/pstl/glue_algorithm_defs.h:249:1: note: 'std::reverse'
249 | reverse(_ExecutionPolicy&& __exec, _BidirectionalIterator __first, _BidirectionalIterator __last);
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/algorithm:63:
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/ranges_algo.h:1292:33: note: 'std::ranges::reverse'
1292 | inline constexpr __reverse_fn reverse{};
/config/esphome/luz-ventilador-dormitorio.yaml:309:16: error: 'forward' was not declared in this scope; did you mean 'std::forward'?
309 | return forward;
| std::forward
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/stl_pair.h:61,
from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/stl_algobase.h:64,
from /data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/array:43,
from src/esphome/components/api/api_frame_helper.h:2:
/data/cache/platformio/packages/toolchain-xtensa-esp-elf/xtensa-esp-elf/include/c++/14.2.0/bits/move.h:82:5: note: 'std::forward' declared here
82 | forward(typename std::remove_reference<_Tp>::type&& __t) noexcept
*** [.pioenvs/luz-ventilador-dormitorio/src/main.cpp.o] Error 1
========================== [FAILED] Took 8.32 seconds ==========================
