Hi, new’ish to HA, and have hopefully an easy question. I have installed the MyQ Garage Door Opener and integrated it with HA. That part is smooth, but I wanted to change the Lovelace UI so that instead of Up/Down Arrows on the Entity Card, it showed ‘Open’ and ‘Close’. Is there an easy way to do that? Additionally, I wanted to ensure similar to the icons, the Text would be Bold if you can action it, and light colored if you can’t select it. Thanks in advance!
Not that I’m aware of with the standard Lovelace components. I’ve recently converted most of my entity rows over to the custom multiple-entity-row and with that you would be able to do what you want and more. https://github.com/benct/lovelace-multiple-entity-row Give it a try.
OK, thanks for the info. Will try it out and let you know.
I have a similar problem. I have 5-6 cover switches with arrows and one of them is “working” in the opposite way from the others (mt awning) . In order to remember which arrow is opens and which is closing, the awning I have the “text” in the description.
eg - Garage Door (open - close).
