Change HA entity from ESPhome
Hi, I have device with 3 buttons. It’s plus/minus/enter running on ESP8266 connected to ESPhome. I’m able to read buttons, make some action. For test, I make number helper in HA and this helper is readed in ESPhome code.
My question is how can I change value of number helper when I hit the button plus. I need increment number in HA by one step, or defined step (in example bellow it’s 0,1)?
Is it possible to make it in lambda?
My part of code:
  - platform: homeassistant
    entity_id: input_number.my_number
    internal: False
binary_sensor:
- platform: gpio
    pin: GPIO12
    on_press:
      then:
       lambda: |-
            id(my_value) = id(my_value) + 0.1;
            id(my_value).publish_state(my_value);
Thank you for reply.
As in HA itself, you cannot change the value of a sensor that way, you have to use an action.
See below to execute an HA action from ESPHome
Most straightforward would be using esphome number component instead of homeassistant sensor/number helper.
number:
    optimistic: true
    min_value: 0.0
    max_value: 100.0
    step: 0.1
    initial_value: 0.0
    restore_value: true
binary_sensor:
  - platform: gpio
    pin: GPIO12
    on_press:
      then:
        - number.increment:
Also, you should enable pullup and delayed on/off filters to your button code.
