I have a home assistant setup with Lutron Hub. It was working great. Recently I had network change and the network ip address changed. Hence the IP of the Lutron hub also changed.
Lutron was configured in HomeAssistant through the “addon configuration”. I did not do manual config. Hence, I am looking to see the config file where the previous IP of the Lutron hub is stored. I want to change the IP configured for Lutron.
How can I do it?
