Change mushroom title depending on energy-date-selection date
Hi people,
I’m trying to change the title depending on a selected day from the energy-date-selection entity. Suppose I have this:
If the date is set to be the current date, the Mushroom title entity’s title should be set to “Stromverbrauch heute” (just like the screenshot shows), however when setting the energy-date-selection entity to a different day, I want the title to be set to “Stromverbrauch vom xx.xx.xxxx”.
How do I achieve this using templates? All entities are being held inside a grid.
All I know is that I can use {% if ... %} but that’s it unfortunately.
I’d be grateful for any help.
Thanks in advance.
This type of Mushroom title or an entity card title?
type: custom:mushroom-title-card
title: Stromverbrauch heute
or this…
This will be necessary either way. I would need a little more info on the energy-date-selection entity to get the template correct.
An example…
type: custom:mushroom-template-card
primary: |
  Stromverbrauch vom {{ now().strftime('%m-%d-%Y') }}
secondary: secondary info
icon: mdi:home
entity: input_datetime.date
icon_color: red
