Hello! I’m kinda new at HA (and mt english is not perfect) and I have a couple of questions…
1st.
I want to set up one HA for my office but I wanted to do it at my place instead of staying late. Is there a way to change the HA network/IP? I know I could enable remote access but I didn’t wanna use duck DNS. Also, I’m using ethernet, not wifi.
2nd.
Also thinking about the office, I want the front desk person to have the HA in the computer but without access to the tabs on the left (hacs, terminal, file editor, config…). Is there a way to only share the views?
After setting up Home Assistant at your house, just before you leave to take it to your office, go to the Supervisor / System / Host panel and click the Change button next to your IP address. Change it to your office network settings. Now this introduces a problem. You can no longer connect to home assistant to shut it down cleanly. Unless you connect a monitor and keyboard and do it via the command line. Like this:
