Change sensor ? Generic field missing
i have a bosch system integration wo works fine. I want to try better thermostat to have visuality from the temps around the day. I read I need to use a generic thermostat. No problem I think but i can install it because the setting switch entry is empty. I can mark the tempsensor but the next entry is missing.What can I do?
I don’t want to install the thermostats directly, so i thinks there is a workaround to rename or so the variable that it will be markable.
Thanks in advice
salo
