I have changed the password for my SMA inverter (Tripower). Since then, logically, the SMA plugin no longer works in my Home Assistant. How can I change the PW in the Home Assistant so that it can access the data again?
Thank you and best regards gerd
Are you using the build-in SMA-Integration or another one?
As far as I know, there is no way to change the password on the UI.
You can change the password in the configuration data, but this is not really recommended.
