Change state of sensor with event?
I flashed an FR Bridge 2 with ESPHome and the data is being received and displayed using the event “esphome.rf_code_received”. I have a Govee 433 MHz water sensor that sends code 006ba32 when moisture is detected and 006ba30 when the button is pushed. I’d like to have a template binary sensor that sets the state wet when the first code is received and dry when the second code is received. Like this in pseudo code:
  - name: "Laundry Moisture"
    unique_id: laundry_moisture
    device_class: moisture
    state: wet with the first code, dry with the second
Is it possible to set the state of a sensor directly from an event being fired, or do I have to have a publish event for each code in the ESPHome yaml in the RF Bridge? Thanks for any help.
So the data is in esphome.
Post your esphome yaml.
This is the RF Bridge yaml:
#Sonoff RF BridgeR2 https://www.irrgang.dev/how-to-flash-the-sonoff-rf-bridger2-with-esphome/
substitutions:
  friendly_name: RF Bridge
esphome:
  friendly_name: ${friendly_name}
esp8266:
  board: esp01_1m
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  services:
    - service: send_rf_code
      variables:
        sync: int
        low: int
        high: int
        code: int
      then:
        - rf_bridge.send_code:
            sync: !lambda 'return sync;'
            low: !lambda 'return low;'
            high: !lambda 'return high;'
            code: !lambda 'return code;'
    - service: learn
      then:
        - rf_bridge.learn
rf_bridge:
  on_code_received:
    then:
      - homeassistant.event:
          event: esphome.rf_code_received
            sync: !lambda 'return format_hex(data.sync);'
            low: !lambda 'return format_hex(data.low);'
            high: !lambda 'return format_hex(data.high);'
            code: !lambda 'return format_hex(data.code);'
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "${friendly_name} ESP"
    password: !secret wifi_password_2
button:
  # Restart the ESP
  - platform: restart
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 19200
captive_portal:
# Sensors for ESP version and WIFI information
text_sensor:
  # ESPHome version
  - platform: version
    hide_timestamp: true
  # IP address and connected SSID
  - platform: wifi_info
    ip_address:
      icon: mdi:wifi
    ssid:
      icon: mdi:wifi-strength-2
  # WiFi signal
  - platform: wifi_signal
    update_interval: 120s
  - platform: uptime
binary_sensor:
  - platform: status
light:
  - platform: status_led
    pin: GPIO13
I have never used RF bridge and the documentation is quite shy.
You could try something like this:
binary_sensor:
    name: "Moisture detected"
rf_bridge:
  on_code_received:
    then:
      - lambda: |-
          if (data.code == 0x006ba32) {
            id(moisture).publish_state(true);
          if (data.code == 0x006ba30) {
            id(moisture).publish_state(false);
I added device class as moisture and this works just as I wanted. Thanks! I have five of these sensors so a lot of copy and paste. I previously had these sensors read by a rtl_433 device to MQTT, but that wasn’t very reliable. This should work better.
You are welcome.
For curiosity, which device you used?
