I have Ubiquity implemented in HA, and notices that all my network devices show up in HA.
However I noticed that de devices have the state home/not home. I would like to change this to online/offline. Is there an easy way to do this for all the device trackers that are added by the integration?
That is because those sensors are set up as device trackers. home/not_home are the default states for device trackers. Can I ask why you want to change it?
If you are going to use them for automation it’s best to use the default states. If it’s to just display the sensor on your dashboard, you can customize the card.
