Morcegolas
(Morcegolas)
December 3, 2024, 4:42pm
1
Change the colour of chips card icon
Hello, I’m trying to change the colour of a icon on a chips card, it’s a light entity and this is what I have, but the colour is always grey.
type: custom:mushroom-chips-card
chips:
- type: entity
entity: light.shelly1pmmini_6055f99ff5d0_switch_0
content_info: none
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon: ""
icon_color: >-
{{ 'green' if states(‘light.shelly1pmmini_6055f99ff5d0_switch_0’) == 'on'
else 'red' }}
Morcegolas
(Morcegolas)
December 4, 2024, 4:53pm
2
Bump!
Anyone that know if this is possible? I think I already had this working some time ago, but I can’t find a working solution.
Try changing the type:
to “template”, assign a specific icon, and then add the template as written below. I used your light entity in my example so you should be a able to copy and paste it. It worked for me so it should work for you. Let me know…
chips:
- type: template
icon: mdi:light-switch
icon_color: |
{% if states('light.shelly1pmmini_6055f99ff5d0_switch_0') == 'on' %}
red
{% else %}
green
{% endif %}
content_info: none
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
would this work for a temp sensor? i woiuld like it to show as blue if its below say 10 celcius and orage between 10 and 30 and red if above 30?
type: entity
entity: sensor.computer_room_temp_sensor
icon_color: accent
No, accent would not be recognized.
Try something like this…
icon_color: |-
{% set state = states('sensor.computer_room_temp_sensor') |int(-1) %}
{% if state >= 50 %} red
{% elif state >= 30 %} orange
{% else %}blue
{% endif %}
thanks for getting back to me so quickly. I have pasted this in but i get the below error
missed comma between flow collection entries (4:2)
1 | type: entity
2 | entity: sensor.computer_room_temp ...
3 | icon_color: |-
4 | {% set state = states('sensor.com ...
5 | {% if state >= 50 %} red
6 | {% elif state >= 30 %} orange
Post the coded vs the error please
type: entity
icon_color: |-
{% else %}blue
{% endif %}
The chip entity card doesn’t allow templating in the icon-color:
field so you need to switch the chip type to template or use card_mod
chips:
- type: template
icon: mdi:thermometer
icon_color: |
{% set state = states('sensor.computer_room_temp_sensor') | int(-1) %}
{% else %}
blue
{% endif %}
Im not getting any error however, the chip is not displaying
Try it in its own card to eliminate other coding errors and post the entire chips card code.
The code works
Even if the icon_color code was wrong the device would still show up, just white.
as you said, certainly works in its own card. can it still show to temp number eg 27.5
Yes, I’ll post an example
chips:
- type: template
content: |
{{ states('sensor.computer_room_temp_sensor') | int(-1)}} °C
icon_color: |
{% else %}
blue
{% endif %}
absolute superstar! I was able to get it into my other chip card as well!
chips:
- type: entity
entity: sensor.computer_room_humidity
- type: template
icon_color: |
{% if state >= 30 %} red
{% elif state >= 18 %} orange
{% else %}
blue
{% endif %}
content: "{{ states('sensor.computer_room_temp_sensor') | int(-1)}} °C"
- type: template
icon: |-
{% if is_state('binary_sensor.computer_room_window', 'off') %}
mdi:window-open
{% else %}
mdi:window-closed
{% endif %}
content: |-
Closed
{% else %}
Open
{% endif %}
icon_color: |-
green
{% else %}
yellow
{% endif %}
tap_action:
action: more-info
entity: binary_sensor.computer_room_window
alignment: center
