Change the description
Hi
I think you should change the information about choosing different measurement systems. Under System->General you have the option to choose Metric or US customary (it’s actually called United States customary units). This thing about you having a choice that you call Metric is the wrong name. It’s called The International System of Units or SI Units and nothing else.
It’s important to use the right name so as not to hurt anyone. You probably remember the space shuttle that crashed due to mixing up different names. But you say Home Assistant is not a space shuttle. OK I accept this but you should use the right name for things, I believe, and also the people who are responsible for these standards.
I hope you make this change for the sake of science.
If this is a Feature Request all the HA webpages have a link to suggesr a change in the document, or you can use:
It will likely not be seen here by anyone that can help with a change.
OK I will. How do I delete this post?
If you can’t delete with the 3 dots button, on your own post do the 3 dots then the flag and ask a mod to help.
Understanding Discourse for new users - Using Discourse - Discourse Meta
