Change value from Wh to KWh
I’ve created an automation that reads out values ​​from our SMA PV system to me. Below is an example.
It’s working fine so far, except that the values ​​are recorded in Wh. However, I would like to have them read out in kWh. Does anyone have any ideas how I can proceed?
action: tts.speak
metadata: {}
  cache: true
  media_player_entity_id: media_player.display_sofa_fully_kiosk
  message: >-
    Du hast heute schon ganze {{states('sensor.gedo_pv_erzeugung_heute')}} KWh
    Strom erzeugt. Gesamt hast du {{states('sensor.sma_pv_gedo_pv_gen_meter')}}
    KWh erzeugt
  entity_id: tts.google_translate_de_de
action: tts.speak
metadata: {}
  cache: true
  message: >-
    Du hast heute schon ganze {{ states('sensor.gedo_pv_erzeugung_heute')|float(0) /1000 }} KWh
    Strom erzeugt. Gesamt hast du {{ states('sensor.sma_pv_gedo_pv_gen_meter') }}
    KWh erzeugt
Thank you. That’s exactly what I was looking for.
That works for me:
Next Automation I have a new Problem.
action: tts.speak
metadata: {}
  cache: true
  message: Der Batterie Status ist {{states('sensor.sma_pv_gedo_battery_status_operating_mode')}}
In the operating mode google speak “charging battery”
How can i translate to “Batterie wird geladen”?
You’d need to add a check/translation into your message along these lines:
{% if states('sensor.sma_pv_gedo_battery_status_operating_mode') == 'charging battery' %}
{% endif %}
The safest way to get the correct string after the == is to find the sensor state in the Developer tools - states.
If you want use different states, e.g. ‘Batterie wird entladen’ or ‘Batterie Status unbekannt’, you’ll have to find out how these states are reported and add a few {% elif %} and/or {% else %} lines to the message.
Thanks a lot. Now I’m finish.
If the dashboard normally shows the right translation, you can also try:
{{ state_translated('sensor.sma_pv_gedo_battery_status_operating_mode') }}
