I am trying to create a dimmable light that I can change over my phone AND using a rotary encoder. It all works fine, except the fact, that my encoder always keeps the last state and doesnt update to the current value of the light. The result is that (If I changed something on my phone) was soon as I turn the knob, the light jumps to the last state of the rotary encoder instead of adding/subtracting to the current light state.
So my question is: How can I read the current state of brightness of my light component in order to pass it to the encoder via:
light:
- platform: binary # or any other platform
on_state:
- sensor.rotary_encoder.set_value:
value: *??VALUEOFLIGHT??*
What do I need to put in for ??VALUEOFLIGHT?? ?
Thank you in advance!
My whole code:
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "3sh6HmIFsLs+12r/HOZo44VHjrFe0BGNLPDKmG0ERZw="
ota:
password: "a6dfa5e175c5db6aaeb97190cfdb5f2f"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "D1-Lichtleiste-Schlafzimmer"
password: "GWOnDwJwq5vi"
captive_portal:
# Example configuration entry
light:
- platform: monochromatic
output: output_pwm_1
# Output für Lichtleiste
output:
- platform: esp8266_pwm
min_power: 0.03
zero_means_zero: true
pin:
number: D8
inverted: false
- platform: rotary_encoder
min_value: 0
max_value: 100
resolution: 2
publish_initial_value: true
pin_a:
number: D1
inverted: true
mode:
input: true
pullup: true
pin_b:
number: D2
inverted: true
mode:
input: true
pullup: true
on_value:
then:
- light.turn_on:
brightness: !lambda "return x/100;"
transition_length: 31ms
