i’m running HA on a raspberry and my zbt-1 is running as thread-device.
i wanted to add my conbee II but failed since i can’t find my USB hardware. i looked under system / hardware but there are no entries for usb.
so i thought i will get an zbt-2 anyway and switch the zbt-1 to zigbee. but also my zbt-1 is nowhere to be found (thread / matter did run well until i deleted the integrations)
i set it up a year ago and it works ever since.
but i can’t see the device, and my conbee2 and a zwave stick can’t be setup.
i searched through the hardware list, no usb device, no entry for tty or searching for by* (was recommended for zigbee setup)
so there can’t be a firmware issue, i tried every usb port, have a 30cm cable as recommended. the zbt-1 works fine, i just can’t change anything or see it.
i then removed all matter integrations and add-ons, now of course my matter devices do not work anymore …
i guess i will take a new sd-card and try a new installation.
