My sensor name is sensor.temperature_158d0001f54788
What is the easiest way to make a easier name for the entity.
Im not talking about the friendly_name
but the actual name to be used in configuration files. ie sensor.kitchentemp
Template sensor and hide the other one in customize
Okey. How would that look like with my example names given?
See here…
and here
sensors:
kitchentemp:
friendly_name: 'Kitchen Temp'
value_template: {{ states.sensor.temperature_158d0001f54788.state | float) }}
Thx for your answer but im missing something, this is my file xiaomisensor.yaml, and the other sensors in this file works.
platform: template
sensors:
front_door:
friendly_name: "Front Door"
value_template: >-
{% if is_state('binary_sensor.door_window_sensor_158d0001f3cc19', 'on') %}
Open
{% else %}
Closed
{% endif %}
icon_template: >
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
balkong_door:
friendly_name: "Balkong Door"
value_template: >-
{% if is_state('binary_sensor.door_window_sensor_158d0001ef3410', 'on') %}
Open
{% else %}
Closed
{% endif %}
icon_template: >
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
edwardtemp:
friendly_name: 'Edward Temp'
And the error i get is:
Testing configuration at /home/homeassistant/.homeassistant
2018-02-19 05:48:23 ERROR (Thread-2) [homeassistant.util.yaml] invalid key: "OrderedDict([('states.sensor.temperature_158d0001f54788.state | float)', None)])"
in "/home/homeassistant/.homeassistant/sensors/xiaomisensor.yaml", line 37, column 0
2018-02-19 05:48:23 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: invalid key: "OrderedDict([('states.sensor.temperature_158d0001f54788.state | float)', None)])"
You have the above in the code and no matching ‘(’, tho’ you don’t need the ‘)’ anyway.
edwardtemp:
value_template: {{ states.sensor.temperature_158d0001f54788.state | float }}
still gives:
2018-02-19 11:13:32 ERROR (Thread-2) [homeassistant.util.yaml] invalid key: "OrderedDict([('states.sensor.temperature_158d0001f54788.state | float', None)])"
2018-02-19 11:13:32 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: invalid key: "OrderedDict([('states.sensor.temperature_158d0001f54788.state | float', None)])"
Any ideas?
{{ (states.sensor.temperature_158d0001f54788.state | float) }}
Try it with both () in there I just tried in the template editor and it works
Okey so code works in template editor at my place to but not in my file, (???). i post it in complete: (First two sensors DO work)
platform: template
sensors:
front_door:
value_template: >-
Open
{% else %}
Closed
{% endif %}
icon_template: >
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
balkong_door:
value_template: >-
Open
{% else %}
Closed
{% endif %}
icon_template: >
mdi:door-open
{% else %}
mdi:door-closed
{% endif %}
edward_temp:
value_template: {{ (states.sensor.temperature_158d0001f54788.state | float) }}
I think in the code it needs to be in single quotes.
