Hi folks. This is probably either so stupid a question or so obvious an that answer nobody else has needed to ask in public (that I can find) and generate the resulting slow hand clap, but here goes.
For entirely cosmetic reasons, I decided to change the DHCP reserved address that my router hands out to the HASSIO instance on my LAN. Note carefully that I did also move my port forwards to the new reserved address before I restarted HASSIO.
I hoped that when it restarted it would grab the new address (it did) and DuckDNS would update the DDNS record for my LetsEncrypt domain & certificate (it did).
So I can SSH into the plugin, no problem, but when I connect to the front end URL I do connect to the device (so the port forward is working) but I get the dreaded “Loading Data” spinner followed by “can’t connect to front end”.
So I put everything back as it was and I’m working again on the old DHCP reservation, but my undercrackers are chafing because it’s not the one I want to use damnit.
Please be gentle, but I can’t find anywhere in the HASSIO or plugin configuration relating to the IP address of the host apart from one line in home-assistant.log:
home-assistant.log:2019-01-14 21:39:53 DEBUG (MainThread) [homeassistant.components.discovery] Already discovered service home_assistant {'host': '172.21.230.66', 'port': 8123, 'hostname': 'Home._home-assistant._tcp.local.', 'properties': {'version': '0.85.1', 'base_url': 'https://[HOSTNAME REDACTED].duckdns.org:8123', 'requires_api_password': True}}.
Can anyone suggest where my foolishness lies?
Mike
