Changing dynamically a custom:button-card's entity inside a config-template-card
Hi everybody,
my purpose is , inside a custom:config-template-card , having a custom:button-card with an entity to toggle from my frontend.
For this reason,this entity is retrieved from the config-template-card container, where a list of entities is available, and, according to some conditions that belong to another thread, when a entity from the list is selected, this one becomes the main entity of the nested custom:button-card which is enabled to be toggled.
I have the evidence of the correct selection of the entity,I tried both the ways to select it as a text ( ‘switch.entity_name’) and as a config template card variable (var[0].entity_id) but it doesnt work.
where is the mistake?
the card:
                      - type: custom:config-template-card
                        variables:
                          - states['input_select.icona_smart_plug_1'].state
                          - states['input_select.icona_smart_plug_2'].state
                          - states['input_select.icona_smart_plug_5'].state
                          - states['input_select.icona_smart_plug_6'].state
                          - states['input_select.icona_smart_plug_7'].state
                          - states['input_select.icona_smart_plug_9'].state
                          - states['input_select.icona_smart_plug_room_1'].state
                          - states['input_select.icona_smart_plug_room_2'].state
                          - states['input_select.icona_smart_plug_room_5'].state
                          - states['input_select.icona_smart_plug_room_6'].state
                          - states['input_select.icona_smart_plug_room_7'].state
                          - states['input_select.icona_smart_plug_room_9'].state
                          - states['switch.smart_plug_1']
                          - states['switch.smart_plug_2']
                          - states['switch.smart_plug_5']
                          - states['switch.smart_plug_6']
                          - states['switch.smart_plug_7']
                          - states['switch.smart_plug_9']
                        entities:
                          - input_select.icona_smart_plug_1
                          - input_select.icona_smart_plug_2
                          - input_select.icona_smart_plug_5
                          - input_select.icona_smart_plug_6
                          - input_select.icona_smart_plug_7
                          - input_select.icona_smart_plug_9
                          - input_select.icona_smart_plug_room_1
                          - input_select.icona_smart_plug_room_2
                          - input_select.icona_smart_plug_room_5
                          - input_select.icona_smart_plug_room_6
                          - input_select.icona_smart_plug_room_7
                          - input_select.icona_smart_plug_room_9
                          - switch.smart_plug_1
                          - switch.smart_plug_2
                          - switch.smart_plug_5
                          - switch.smart_plug_6
                          - switch.smart_plug_7
                          - switch.smart_plug_9
                        element:
                          type: custom:button-card
                          show_name: false
                          show_state: false
                          show_label: true
                          entity: >-
                            ${vars[6] === '18' ? vars[12].entity_id : vars[7]
                            ==='18' ? vars[13].entity_id : vars[8] == '18' ?
                            vars[14].entity_id : vars[9] == '18'  ?
                            vars[15].entity_id : vars[10] === '18' ?
                            vars[16].entity_id : vars[11] === '18' ?
                            vars[17].entity_id : 'none'}
                          card_mod:
                            style: >
                              @keyframes my-blink { from {opacity: 0;} to
                              {opacity: 100;}
                                from {opacity: 100;} to {opacity: 0;}   }
                              @keyframes  rotation{
                                      0%   { transform: rotate(0deg); }
                                      100% { transform: rotate(360deg);  }
                          tap_action:
                            action: toggle
It is not recommended to place button card into CTC.
Consider other ways.
Unrelated: card-mod code seems to be rather weird, are you sure it works? Unused “rotation”; weirdly defined and also unused “blinking” - is it a product of chatgpt?
Unrelated: in CTC, in some cases like yours it is better to refer a variable by a name, not by an index. Easier, more maintainable.
Btw, according to docs, it is possible to use a template for “entity_id” option in some extent, suggest to confirm this in the main thread for this button-card.
