Hi all,
I’ve seen a few folks mention that the Ring contact/door sensors show in HomeKit with 0% battery life even though HA shows it coorectly. I’ve reviewed the diagnostic file for the HomeKit bridge exposing the contact sensors and I know the problem is that the “linked_battery_sensor” attribute is set to expose the temperature - which is 0 because these sensors do not include temp. The thing is that I cannot figure out where to change this “linked_battery_sensor” without doing a completely customer HomeKit entry in the configuration.yaml file. Can someone point me in the right direction to change the “linked_battery_sensor” attribute of an entity within a particular HomeKit bridge?
TIA.
Here is the diagnostic.json snippet from the bridge that shows the incorrect sensor being used for linked_battery_sensor attribute.
"bridge": {
"1399065732": {
"aid": 1399065732,
"config": {
"manufacturer": "Ring",
"model": "4SD2SZ-0EN0",
"sw_version": "1.40.6",
"platform": "zwave_js",
"linked_battery_sensor": "sensor.sliding_glass_door_temperature"
"category": 10,
"name": "Sliding glass door Intrusion",
"entity_id": "binary_sensor.sliding_glass_door_intrusion",
"entity_state": {
"state": "off",
"attributes": {
"device_class": "door",
"friendly_name": "Sliding glass door Intrusion"
"last_changed": "2025-04-19T13:25:00.087007+00:00",
"last_reported": "2025-04-19T13:25:00.087007+00:00",
"last_updated": "2025-04-19T13:25:00.087007+00:00",
"context": {
"id": "01JS73JK1QHJCX1KR035C0H1BT",
"parent_id": null,
"user_id": null
"1356175039": {
"aid": 1356175039,
"config": {
"linked_battery_sensor": "sensor.pool_door_temperature"
"category": 10,
"name": "Pool Door Intrusion",
"entity_id": "binary_sensor.pool_door_intrusion",
"entity_state": {
"state": "off",
"attributes": {
"friendly_name": "Pool Door Intrusion"
"last_changed": "2025-04-19T01:38:22.767878+00:00",
"last_reported": "2025-04-19T01:38:22.767878+00:00",
"last_updated": "2025-04-19T01:38:22.767878+00:00",
"context": {
"id": "01JS5V4QDF7R7HM9P0QXGPCG9X",
"parent_id": null,
"user_id": null
"2421328862": {
"aid": 2421328862,
"config": {
"linked_battery_sensor": "sensor.front_door_temperature"
"category": 10,
"name": "Front Door Intrusion",
"entity_id": "binary_sensor.front_door_intrusion",
"entity_state": {
"state": "off",
"attributes": {
"friendly_name": "Front Door Intrusion"
"last_changed": "2025-04-19T04:37:47.675381+00:00",
"last_reported": "2025-04-19T04:37:47.675381+00:00",
"last_updated": "2025-04-19T04:37:47.675381+00:00",
"context": {
"id": "01JS65D80VJHWHXP91XCRHME2B",
"parent_id": null,
"user_id": null
"2861255081": {
"aid": 2861255081,
"config": {
"linked_battery_sensor": "sensor.laundry_garage_door_temperature"
"category": 10,
"name": "Laundry - Garage Door Intrusion",
"entity_id": "binary_sensor.laundry_garage_door_intrusion",
"entity_state": {
"state": "off",
"attributes": {
"friendly_name": "Laundry - Garage Door Intrusion"
"last_changed": "2025-04-19T01:38:22.844849+00:00",
"last_reported": "2025-04-19T01:38:22.844849+00:00",
"last_updated": "2025-04-19T01:38:22.844849+00:00",
"context": {
"id": "01JS5V4QFWP9P1QSZSXCHYJXAV",
"parent_id": null,
"user_id": null
