Changing logger level based on input_boolean?
I was thinking about the possibility to switch the logger level from info to debug for a certain component based on an input_boolean in the front-end.
Basically I would need to dynamically change the line in configuration.yaml from custom_component: info to custom_component: debug. Is it possible?
See service logger.set_level.
