I just bought one of these and a SONOFF Zigbee USB dongle. I plugged in the dongle, and HomeAssistant immediately recognized the dongle and then discovered the valve via ZHA.
My valve is automatically shutting off within an hour of using water. Apparently you can change this if you use Z2MQTT, presumably by changing some config setting. Can/How this be done with the ZHA implementation?
