I’m not 100% positive on this, but couldn’t you introduce your new stick as a backup controller on the old network, then make the backup stick the primary?
You probably will have to use OpenZWave to do this, as I don’t think the HASS ZWave panel can do this. I could be wrong though. It definitely wouldn’t be the first time.
Curious if you have successfully moved to using the HUSBZB-1 stick with HA. I currently have a Aeon Z-Stick Gen5 that works flawlessly but recently received the HUSBZB-1 as a gift. If you have made the switch can you provide some info on what you did and any challenges you ran into. I’d be interested to try it but nervous about messing up a perfectly good setup at the moment. Any chance it’s as easy as unplugging the one and plugging this in and have it read the existing zwcfg.xxx file and not miss a beat ? (probably not)
Also, have you integrated any zigbee products using the HUSBZB-1 and how did that go? - Thx
I know this is an old thread but i am pretty much doing the same thing switching out the sticks. Anyway of switching it out without unpairing all the devices and then pairing them again? I feel like a lot of people will be doing this as Pi4 doesn’t seem to be working with Aeotec stick
I did read something about passing it through a usb hub to get it work on I pi4… don’t know the details but it’s definitely something I read in the last few days…
“That would require removing all the devices from the current stick,
and then including them with the new stick.”
…hahah welp that answered my question. I thought I would go the upgrade route and get a different stick… Setting up 50 devices all over again is something I am not going to do
i thought there might be a way to edit some config file
